跳转到主内容
iDeaUSA CT8 Speaker Replacement
你所需要的
  1. iDeaUSA CT8 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 iDeaUSA CT8 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 iDeaUSA CT8 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Place the front and back portion of the tablet close in proximity and have both of them face upwards while being cautious of the wire connecting the speaker to the motherboard.
  2. iDeaUSA CT8 Speaker Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Locate the two wires connecting the speaker to the motherboard.
    • With tweezers, gently pull the red and black wires out of their sockets.
    • A soldering kit is required to reconnect the speaker to the motherboard.
  3. iDeaUSA CT8 Speaker Replacement: 步骤 3 中的图像 1,2 iDeaUSA CT8 Speaker Replacement: 步骤 3 中的图像 2,2
    • On the tablet’s back cover, locate the two 4 mm screws on the speaker.
    • Use the #000 Phillips screwdriver to remove the screws and place them in an appropriate location.
  4. iDeaUSA CT8 Speaker Replacement: 步骤 4 中的图像 1,2 iDeaUSA CT8 Speaker Replacement: 步骤 4 中的图像 2,2
    • Using a metal spudger, safely separate the speaker from its socket.
  5. iDeaUSA CT8 Speaker Replacement: 步骤 5 中的图像 1,2 iDeaUSA CT8 Speaker Replacement: 步骤 5 中的图像 2,2
    • The speaker is now removed and can be replaced accordingly.
    • Remember that to ensure a connection, you will need to solder the new wire connections onto the motherboard.
结论
To reassemble your device, follow these instructions in reverse order. A soldering kit will be required to ensure a connection between the speaker and motherboard after the replacement is complete.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 98
