跳转到主内容
iDeaUSA CT8 Power Button Replacement
你所需要的
  1. iDeaUSA CT8 Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 iDeaUSA CT8 Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 iDeaUSA CT8 Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Place the tablet on a flat surface, facing upwards.
    • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
    • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
  2. iDeaUSA CT8 Power Button Replacement: 步骤 2 中的图像 1,2 iDeaUSA CT8 Power Button Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • On the tablet’s back cover, locate the power button.
    • Use tweezers to remove button’s padding that holds it in place.
  3. iDeaUSA CT8 Power Button Replacement: 步骤 3 中的图像 1,1
    • To remove the power button, use a plastic opening tool to nudge the button out of position.
    • A gentle push from the button’s exterior side should be enough.
  4. iDeaUSA CT8 Power Button Replacement: 步骤 4 中的图像 1,1
    • The power button is now removed. Adjust accordingly or replace it
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 114
