跳转到主内容
iDea USA CT702 Microphone Replacement
你所需要的
  1. iDea USA CT702 Microphone Replacement, Microphone: 步骤 1 中的图像 1,1
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: 步骤 2 中的图像 1,2 iDea USA CT702 Microphone Replacement: 步骤 2 中的图像 2,2
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: 步骤 3 中的图像 1,3 iDea USA CT702 Microphone Replacement: 步骤 3 中的图像 2,3 iDea USA CT702 Microphone Replacement: 步骤 3 中的图像 3,3
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: 步骤 4 中的图像 1,1
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: 步骤 5 中的图像 1,1
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
结论
Benton Gray
于03/11/15注册
201 声望
创作了2篇指南
团队
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 118
