跳转到主内容
iDea USA CT 1020 Front & Rear Camera Assembly Replacement
你所需要的
  1. iDea USA CT 1020 Front & Rear Camera Assembly Replacement, Front & Rear Camera Assembly: 步骤 1 中的图像 1,1
    • First, power down the tablet to avoid the chance of electrical shock or damaging the machine during repair work
    • Place the tablet on a clean surface with the screen down
  2. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: 步骤 2 中的图像 1,2 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the back plastic casing of the tablet by releasing the plastic clips with a plastic opening tool or a spudger.
    • Be cautious and take your time here; the plastic clips are quite fragile.
  3. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool or spudger to lift and release the camera assembly ZIF tab.
    • Gently pull the ribbon cable free.
  4. iDea USA CT 1020 Front & Rear Camera Assembly Replacement: 步骤 4 中的图像 1,2 iDea USA CT 1020 Front & Rear Camera Assembly Replacement: 步骤 4 中的图像 2,2
    • The camera is held in place by adhesive material on the back of the camera
    • To complete removal, peel the camera off the mother board
结论
另外一个人完成了本指南。
David Lawrence
于01/22/18注册
109 声望
撰写一个指南
团队
IUPUI, Team S1-G3, Freund Spring 2018 IUPUI, Team S1-G3, Freund Spring 2018 的会员
IUPUI-FREUND-S18S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 116
