跳转到主内容
iBook G4 14" 1.42 GHz Hard Drive Replacement
你所需要的
  1. iBook G4 14" 1.42 GHz Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 iBook G4 14" 1.42 GHz Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 14" 1.42 GHz Hard Drive Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Loosen the four silver Phillips screws that secure the RAM shield.
    • These screws will not come out all the way. The screws are held captive to the RAM shield to prevent them from getting lost.
  4. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the RAM shield from the computer.
    • The four captive screws will come out with the RAM shield.
  5. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • When reassembling your iBook, make sure that you reconnect the keyboard cable before replacing the RAM shield.
  6. iBook G4 14" 1.42 GHz Hard Drive Replacement, Lower Case: 步骤 6 中的图像 1,1
    • Close the display and flip the computer over.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center.
    Oop's sorry on my earlier note I meant to say in step 2
    Keith - 回复
    In my iBook G4 (Fr), there's no T8 Torx but nut driver.
    boninj - 回复
  7. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
    Be careful, the rubber feet tend to jump out and get lost.
    Lakshmana - 回复
  8. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the three newly-revealed Phillips screws.
    • One screw is underneath each bumper (three total).
  9. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  10. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Remove the two Phillips screws on either side of the battery contacts.
  11. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
    This part scared me, never in an iFixIt guide have I seen a warning like "trying times are ahead".
    I used a plastic iPod opening tool and ran it around the seam in the same order pictured. I had the plastic off in less than a minute with almost no fuss.
    PohTayToez - 回复
  12. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 12 中的图像 1,1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  13. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 13 中的图像 1,1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  14. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 14 中的图像 1,1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  15. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 15 中的图像 1,1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  16. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 16 中的图像 1,1
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
    I found it easier and "safer" to use a spudge at the back as well (two on each side of the hinge)
    Paulix - 回复
    来自 Paulix 的话:
    I did too. Thanks, Paulix.
    Ryan Cabanas - 回复
  17. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 17 中的图像 1,1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  18. iBook G4 14" 1.42 GHz Hard Drive Replacement, Bottom Shield: 步骤 18 中的图像 1,1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  19. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 19 中的图像 1,1
    • Lift the bottom shield off.
  20. iBook G4 14" 1.42 GHz Hard Drive Replacement, DC-In Board: 步骤 20 中的图像 1,1
    • Remove the single Phillips screw securing the DC-In board.
    You might not need to remove the entire DC-In board and cable. This is removed because the DC-In jack blocks the upper case from being lifted off. I just removed the screw and pushed the board slightly in when removing the upper case to provide clearance. You may want to tape the board loosely in place when the screw is out to prevent it from falling out.
    georgie333 - 回复
  21. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 21 中的图像 1,1
    • Angle the DC-In board out of its compartment.
    • You may need to remove tape that secures the DC-In board cable to the case.
    You need to undo the adhesive halfway down the cable, so you can lift the DC board to angle it out correctly. beefybov
    beefybov - 回复
    来自 beefybov 的话:
    Good call, beefybov.
    Ryan Cabanas - 回复
  22. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 22 中的图像 1,1
    • Lift the DC-In cable from the adhesive attaching it to the logic board.
  23. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 23 中的图像 1,1
    • Disconnect the DC-In cable from the logic board.
    • Wiggling the connector parallel to the surface of the logic board while applying slight tension may aid in removal.
  24. iBook G4 14" 1.42 GHz Hard Drive Replacement, Upper Case: 步骤 24 中的图像 1,1
    • Remove the following 11 screws from the bottom of the computer:
    • Three 3 mm Phillips around the battery compartment.
    • Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
    • One 12 mm Phillips in the lower right corner.
    • Four 14.5 mm Phillips.
    On my model, both left-side screws are short and the (lower) right screw is the long one.
    axel - 回复
    Sorry, this note should be for Step 25!
    axel - 回复
  25. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 25 中的图像 1,1
    • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
    • Turn over the computer and open it.
    • Remove the 3 Phillips screws from the edges of the keyboard area.
    • The shorter screw goes in the lower left corner. The left corner is indicated by a blue "L" in the photograph and is on the right side.
    A soft cloth like the one you use to clean your screen with. Not a towel because of the static that might be built up in heavier fabrics.
    2myownbeat - 回复
    The picture has the lower *right* screw marked as "L" -- but that's a mistake; the short screw is, as described, on the lower LEFT side.
    Peter King - 回复
    On my computer, the screw in lower right marked "L" (long?) in the picture is M3x6mm and the other two are M3x3mm.
    donestabrook - 回复
    Long screw goes into the right bottom corner - and the 3 mm on the left - at least at the computer I did.
    zhp - 回复
    Yes, the LONG screw goes into the bottom RIGHT corner if the screen is facing you as it does when you're using the computer.
    Sugar Fish - 回复
  26. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 26 中的图像 1,1
    • Be especially careful while disconnecting the cables in the forthcoming steps. Never pull directly on the cables, but use a spudger to pry up the connector directly from its socket.
    • Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
    • Be careful while lifting the upper case, as its tabs are still hanging on the metal frame.
  27. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 27 中的图像 1,1
    • The sockets attached to the motherboards of most iBooks are very weak and easily broken. Use extreme caution when pulling connectors out of their sockets.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails, carefully pry the connector from its socket.
    • Carefully disconnect the multicolored speaker cable from the logic board in the same fashion.
    use 2 tweezers instead: One with a fine tip to hold down the female socket and the other (or your fingernails) to pry up the male connector. That way you can better prevent the female socket to break off from the motherboard.
    Christian - 回复
    This is a very tough one. I did break both the power cable and speaker cable off the motherboard, and was unable to separate the motherboard-side connectors from the cable-side connectors even after that. Fortunately, this iBook was already bricked.
    Sugar Fish - 回复
  28. iBook G4 14" 1.42 GHz Hard Drive Replacement, Top Shield: 步骤 28 中的图像 1,1
    • Remove the following 16 screws:
    • Thirteen 3 mm Phillips.
    • One 3 mm Phillips.
    • Two 4 mm Phillips.
    • During reassembly, be sure to fit the screw near the left hinge through the loop in the display data cable, securing the cable to the upper case.
    on my model, the upper yellow screw and the orange screw were 3mm as well (red colour). So only the one right yellow screw was 4 mm.
    Paulix - 回复
    On my computer there is only one 4mm screw. The leftmost bottom right. The others are 3 mm. It is actually written on the shield: M2X3 = 3 mm. M2X4 = 4 mm.
    Paulix - 回复
    The little tabs on the shield that are intended to contact the metal on the ports and the optical drive had been flattened out on my iBook and were no longer in contact. I didn't notice this until I had installed the shield. Make sure the tabs are bent down a bit as to contact the ports and optical drive. This system looks like it replaced the foil tape on earlier models. Just my own observation.
    randy3833 - 回复
  29. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 29 中的图像 1,1
    • Lift the top shield up from the right side, minding the upper left corner which may catch on the metal framework.
  30. iBook G4 14" 1.42 GHz Hard Drive Replacement, Hard Drive: 步骤 30 中的图像 1,1
    • Remove the four Phillips screws securing the hard drive to the metal framework.
    • Remove the following three 3 mm Phillips screws from the metal AirPort card retaining bracket.
    • Lift the metal AirPort card retaining bracket up and out of the computer.
  31. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 31 中的图像 1,1
    • Lift the free end of the hard drive up, enough for the brackets to clear the metal frame. Pull the hard drive out of its connector.
  32. iBook G4 14" 1.42 GHz Hard Drive Replacement, Hard Drive: 步骤 32 中的图像 1,1
    • Remove the hard drive brackets from the left and right sides of the hard drive.
  33. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 33 中的图像 1,1
    • Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
  34. iBook G4 14" 1.42 GHz Hard Drive Replacement: 步骤 34 中的图像 1,1
    • Disconnect the hard drive connector from the hard drive.
    • This is a bit tricky. Try rocking the connector gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
    iFixit,
    Thank you for this helpfull guide.
    It took me exactly 70 min. to swap the harddisk, this including a cup of coffee and a smoke between disassembly/assembly.
    Thumbs up!
    Patrick van Helden - 回复
结论
83等其他人完成本指南。
附加文件
6条评论
Actually, I found a Phillips 0 (PH0) a better option on all the smallest screws than a PH00. That was at least my experience.
Paulix - 回复
My iBook G4 had some differences… there was a bracket retaining the HDD, screw placements weren't quite the same, the 'L' screw in Step 25 is actually a larger headed screw. Success achieved. Dead drive removed for destruction.
Monica I - 回复
Thank you community "iFixit". I just replaced the HD in an iBook G4 14 "with the help of the guide Walter Galan.
Great photos and precise instructions step by step.
Vitor
Vitor - 回复
Wow!! Who knew it would be so complicated?!? I just wanted to pull the hard drive out before recycling the old case and never would have figured it out on my own. Thanks so much for posting these instructions.
posting ID - 回复
A lot of these steps aren‘t necessary. Especially to save yourself the trouble: do not disconnect the power button and speaker-it works fine with having the shield next to the iBook with the cables still threaded through the metal sheet.
Benjamin Grunmaurer - 回复
I just wanted to pull the hard drive out before recycling the old case. Thanks so much for posting these instructions.
richard A - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 97
总计 85,914
