简介
Tripped over your power cord? At least you don't have to replace the entire logic board.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Close the display and flip the computer over.
Remove the three hex screws using a T8 Torx screwdriver.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
62等其他人完成本指南。
附加文件
4条评论
This was a really easy guide thanks. I had ordered a replacement DC in board but found after opening I could have probably repaired the existing one. It had been tripped over a few too many times. I think a bit of re-soldering on the connector where the tape covers in step 17 may have fixed mine. Now I have a backup at least.
Hi,
Does anyone happen to know the values of the L2 and L3 parts on this DC-in board?
I am looking to reuse them but I cannot find any specs.
Thank you and regards,
Vincent
