简介
iBook not working under battery power even with a good battery? Extend your range beyond that wall socket and use this guide to replace your battery connector.
你所需要的
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Close the display and flip the computer over.
Remove the three hex screws using a T8 Torx screwdriver.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Remove the two Phillips screws securing the battery connector to the metal framework.
3等其他人完成本指南。
