本指南有最近更改,您可查看未经巡查的最新版本。
简介
Upgrade or replace the CD, DVD, combo or SuperDrive.
你所需要的
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Remove the following 15 screws:
Fourteen 3 mm Phillips.
One 5.5 mm Phillips in the upper left corner.
Remove the following 4 screws:
One 3 mm Phillips in the channel between the optical drive and fan.
Two 6 mm Phillips from either end of the drive bezel.
One 6 mm Phillips with a collar from the bracket extending from the lower left corner of the drive.
26等其他人完成本指南。
