跳转到主内容
iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement, LCD Cover: 步骤 1 中的图像 1,1
    • Remove the large piece of tape near the lower right corner of the display.
  2. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 2 中的图像 1,2 iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display (it's the first of the two clutch cover screws).
    • Use the tip of a spudger to remove the small washer under the screw you just removed.
  3. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 3 中的图像 1,1
    • Peel the aluminum/EMI tape as one piece off the cast aluminum frame of the clutch hinges.
    • It is not necessary to peel the tape off the thin steel LCD cover.
  4. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the pieces of readily removable tape from around the perimeter of the display.
  5. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 5 中的图像 1,2 iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 5 中的图像 2,2
    • Remove the piece of aluminum tape near the center of the LCD cover.
    • Peel back the piece of tape securing the display data cable ground loop to the thin steel LCD cover.
  6. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 6 中的图像 1,2 iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 6 中的图像 2,2
    • Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
  7. iBook G4 12" 800 MHz-1.2 GHz LCD Cover Replacement: 步骤 7 中的图像 1,1
    • Lift the thin steel LCD cover off the LCD.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 512
