跳转到主内容
简介
Replacing this keyboard is easy and takes only a few minutes.
  1. Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. Lift the battery out of the computer.
    • Lift the battery out of the computer.
  3. Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. If the computer has an AirPort card installed, follow the next three steps to remove it.
    • If the computer has an AirPort card installed, follow the next three steps to remove it.
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. Grasp the clear plastic tab on the AirPort card and pull toward the display.
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
  7. Remove the four silver Phillips screws that secure the RAM shield.
    • Remove the four silver Phillips screws that secure the RAM shield.
  8. Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  9. Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
结论
12等其他人完成本指南。
附加文件
iRobot
于2009年09月24日注册
1 信誉积分
创作了647篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 15,811
