跳转到主内容
加入维修社区 - 创建账户
iBook G4 12" 800 MHz-1.2 GHz Fan Replacement
你所需要的
  1. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    询问修复机器人
    添加评论
  2. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out of the computer.
    询问修复机器人
    添加评论
  3. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement, Lower Case: 步骤 3 中的图像 1,1
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    添加评论
  4. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the three newly-revealed Phillips screws.
    询问修复机器人
    添加评论
  5. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 5 中的图像 1,1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    添加评论
  6. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the three Torx screws using a T8 Torx screwdriver.
    • The shorter screw is in the center of the computer.
    添加评论
  7. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the two Phillips screws on either side of the battery contacts.
    添加评论
  8. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 8 中的图像 1,1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    添加评论
  9. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 9 中的图像 1,1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    询问修复机器人
    添加评论
  10. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 10 中的图像 1,1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    询问修复机器人
    添加评论
  11. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 11 中的图像 1,1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
    添加评论
  12. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 12 中的图像 1,1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
    添加评论
  13. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 13 中的图像 1,1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and away from you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
    添加评论
  14. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 14 中的图像 1,1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    询问修复机器人
    添加评论
  15. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement, Bottom Shield: 步骤 15 中的图像 1,1
    • Remove the 4 Phillips screws from the bottom shield.
    • The two longer screws are along the computer's edge, near the ports.
    添加评论
  16. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 16 中的图像 1,1
    • Lift the bottom shield off.
    询问修复机器人
    添加评论
  17. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement, Fan: 步骤 17 中的图像 1,1
    • Remove the 4 Phillips screws securing the fan to the metal framework.
    询问修复机器人
    添加评论
  18. iBook G4 12" 800 MHz-1.2 GHz Fan Replacement: 步骤 18 中的图像 1,1
    • Lift the fan out of its compartment and disconnect it from the logic board, removing tape as necessary.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 44
总计 11,395
