跳转到主内容
修复你的物品
维修的权力
商店
简介
Replacing the pulsing white LED sleep indicator.
  1. Lay your iBook upside down on a flat surface. Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. Remove the four silver Phillips screws that secure the RAM shield.
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
  5. Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
  6. Remove the three newly-revealed Phillips screws.
    • Remove the three newly-revealed Phillips screws.
  7. Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  8. Remove the three hex screws using a T8 Torx screwdriver.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center of the computer.
  9. Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
    • Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
  10. Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  11. There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  12. Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  13. Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
    • Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  14. There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  15. The front and sides of the lower case are now free.
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
  16. Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    • Have patience and follow the directions, the end result is up to you. In my case it worked. But I was a Technician TRW Automotive. and worked on Air Bag modules that was returned from customer's that needed them analyzed. I just retired after 26 years.
  17. Remove the following 4 screws from the bottom shield:
    • Remove the following 4 screws from the bottom shield:
    • Two 3 mm Phillips.
    • Two 7.5 mm Phillips.
  18. Lift the bottom shield off.
    • Lift the bottom shield off.
  19. Remove the two Phillips screws securing the DC-In board, removing tape as necessary.
    • Remove the two Phillips screws securing the DC-In board, removing tape as necessary.
  20. Deroute the cable from around the optical drive, removing tape as necessary. Disconnect the DC-In cable from the logic board and angle the DC-In board out of its compartment.
    • Deroute the cable from around the optical drive, removing tape as necessary.
    • Disconnect the DC-In cable from the logic board and angle the DC-In board out of its compartment.
  21. Remove the two 3 mm Phillips screws inside the left edge of the battery tray.
    • Remove the two 3 mm Phillips screws inside the left edge of the battery tray.
    • Three 3 mm Phillips around the battery compartment.
    • Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
    • One 12 mm Phillips in the lower right corner.
    • Four 14.5 mm Phillips.
  22. We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
    • We recommend placing the computer on a soft cloth from this point on to prevent damaging the logic board.
    • Turn over the computer and open it.
    • Use the flat side of a flathead screwdriver to remove the small magnet covering a screw near the middle of the computer.
    • The shorter screw goes in the lower left corner.
  23. Remove the following 7 screws from the edges of the keyboard area.
    • Remove the following 7 screws from the edges of the keyboard area.
    • Three 2 mm Phillips along the right edge.
    • One 4.5 mm Phillips underneath where the magnet was.
    • One 6 mm Phillips with a small head in the lower left corner.
    • Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle.
  24. Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
    • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
    • Carefully lift the upper case slightly and move it toward the front of the computer to reveal the trackpad connector. Use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
    • After disconnecting the track pad connector, carefully rotate the upper case away from you and rest it against the display.
  25. The connectors at the ends of the following cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • The connectors at the ends of the following cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Use the sharp end of a spudger to disconnect the speaker cable connector.
  26. Using the sharp end of a spudger, disconnect the connector for the blue and white power cables.  Again, be careful to pry up only on the connector. It is very easy to break the connector from the board, so be careful.
    • Using the sharp end of a spudger, disconnect the connector for the blue and white power cables. Again, be careful to pry up only on the connector.
    • It is very easy to break the connector from the board, so be careful.
    • The key is to apply force in two directions, down to keep the surface board connections intact, up to release the connector.
    • The upper case is now free and can be removed from the computer.
  27. Remove the single Phillips screw securing the sleep light to the metal framework.
    • Remove the single Phillips screw securing the sleep light to the metal framework.
  28. Turn the computer over and disconnect the sleep light from the logic board.
    • Turn the computer over and disconnect the sleep light from the logic board.
结论
附加文件
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 1
总计 2,538
