跳转到主内容
iBook G4 12" 1.33 GHz Rear Display Bezel Replacement
你所需要的
  1. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Battery: 步骤 1 中的图像 1,2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Battery: 步骤 1 中的图像 2,2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: 步骤 2 中的图像 1,2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: 步骤 2 中的图像 2,2
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  3. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 3 中的图像 1,2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 3 中的图像 2,2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  4. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 4 中的图像 1,1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  5. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 5 中的图像 1,2 iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 5 中的图像 2,2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  6. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 6 中的图像 1,1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  7. iBook G4 12" 1.33 GHz Rear Display Bezel Replacement: 步骤 7 中的图像 1,1
    • Lift the rear bezel off the display assembly.
结论
3等其他人完成本指南。
附加文件
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,473
