本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replace a broken LCD/Backlight with the display still attached to your iBook.
你所需要的
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
即将完成!
结论
12等其他人完成本指南。
