跳转到主内容
iBook G4 12" 1.33 GHz Keyboard Replacement
你所需要的
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,2 iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: 步骤 4 中的图像 1,1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
结论
10等其他人完成本指南。
附加文件
一条评论
The screw is stripped. What should I do?
TheYootz Media Group - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 10,276
