本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replacing a defective fan is pretty easy and will keep your laptop running cool.
你所需要的
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
Remove the following 4 screws from the bottom shield:
Two 3 mm Phillips.
Two 7.5 mm Phillips.
2等其他人完成本指南。
