跳转到主内容
iBook G3 Clamshell CD Faceplate Replacement
你所需要的
  1. iBook G3 Clamshell CD Faceplate Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell CD Faceplate Replacement, CD Faceplate: 步骤 2 中的图像 1,1
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  3. iBook G3 Clamshell CD Faceplate Replacement: 步骤 3 中的图像 1,1
    • Remove the single black Phillips screw from the center of the CD-ROM bezel.
  4. iBook G3 Clamshell CD Faceplate Replacement: 步骤 4 中的图像 1,1
    • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
结论
6等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
2条评论
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - 回复
Help I've broke my drive cover and it won't go back on how do I fix that
Mr. Yee Macinuwm - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 10,128
