跳转到主内容
加入维修社区 - 创建账户
iBook G3 14" Keyboard Replacement
你所需要的
  1. iBook G3 14" Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G3 14" Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G3 14" Keyboard Replacement: 步骤 3 中的图像 1,1
    • If your computer does not have an AirPort card installed, skip to the RAM shield removal step.
    • Push the wire clasp toward the AirPort card and pull it up to free it from the RAM shield.
  4. iBook G3 14" Keyboard Replacement: 步骤 4 中的图像 1,1
    • Grasp the clear plastic tab on the AirPort card and pull toward the right.
  5. iBook G3 14" Keyboard Replacement: 步骤 5 中的图像 1,1
    • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
  6. iBook G3 14" Keyboard Replacement: 步骤 6 中的图像 1,1
    • Remove the two Phillips screws that secure the RAM shield.
  7. iBook G3 14" Keyboard Replacement: 步骤 7 中的图像 1,1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
  8. iBook G3 14" Keyboard Replacement: 步骤 8 中的图像 1,1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
结论
8等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 58
总计 7,920
