简介
Use this guide to replace your inverter/AirPort cables.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Remove the following 4 screws on the bottom of the computer:
Two 3 mm Phillips from the left side of the computer.
One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
One 14.2 mm Phillips near the front, right corner.
Remove the following 14 screws (some models may be missing a couple of screws):
One 2.5 mm Phillips.
Six 3.5 mm Phillips.
One 4.5 mm Phillips near the sleep light with a small shaft.
Two 4.5 mm Phillips with larger shafts.
Four 5 mm Phillips
If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
Your laptop should look approximately like this.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Remove the two pieces of tape over the display data/microphone cables near the lower edge of the display.
Remove the two pieces of tape covering the inverter/AirPort cables along the lower edge of the display.
8等其他人完成本指南。
附加文件
3条评论
Excellent guide.
I have been through about half of this, replacing a failed hard disk. After an hour or so, it's like "You gotta be kidding me..."
If it makes you feel any better, this iBook disassembly is easier than its sibling, the lampshade iMac.
