本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replace a faulty display inverter with the display attached to your iBook.
你所需要的
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the pieces of tape holding the inverter and the inverter cables to the clutch hinges.
6等其他人完成本指南。
