跳转到主内容
hp spectre 13-3010dx Track Pad Replacement
你所需要的
  1. hp spectre 13-3010dx Track Pad Replacement, Removal of the Back Case: 步骤 1 中的图像 1,2 hp spectre 13-3010dx Track Pad Replacement, Removal of the Back Case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. hp spectre 13-3010dx Track Pad Replacement: 步骤 2 中的图像 1,2 hp spectre 13-3010dx Track Pad Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. hp spectre 13-3010dx Track Pad Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. hp spectre 13-3010dx Track Pad Replacement: 步骤 4 中的图像 1,1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. hp spectre 13-3010dx Track Pad Replacement: 步骤 5 中的图像 1,2 hp spectre 13-3010dx Track Pad Replacement: 步骤 5 中的图像 2,2
    • Gently lift up the battery and remove using the plastic opening tools.
  6. hp spectre 13-3010dx Track Pad Replacement, Track Pad: 步骤 6 中的图像 1,1
    • Unscrew the five 2.3 mm screws using the PH000 screw head.
  7. hp spectre 13-3010dx Track Pad Replacement: 步骤 7 中的图像 1,1
    • Lift up the latch using the nylon spudger.
  8. hp spectre 13-3010dx Track Pad Replacement: 步骤 8 中的图像 1,1
    • Disconnect the ribbon.
  9. hp spectre 13-3010dx Track Pad Replacement: 步骤 9 中的图像 1,1
    • Lift out the track pad.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 1,364
