跳转到主内容
hp pavilion 15-cc023cl Motherboard Replacement
你所需要的
  1. hp pavilion 15-cc023cl Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 hp pavilion 15-cc023cl Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 3 中的图像 1,2 hp pavilion 15-cc023cl Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 4 中的图像 1,2 hp pavilion 15-cc023cl Motherboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 10 中的图像 1,2 hp pavilion 15-cc023cl Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 11 中的图像 1,1
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 12 中的图像 1,1
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 13 中的图像 1,1
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 14 中的图像 1,3 hp pavilion 15-cc023cl Motherboard Replacement: 步骤 14 中的图像 2,3 hp pavilion 15-cc023cl Motherboard Replacement: 步骤 14 中的图像 3,3
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 15 中的图像 1,2 hp pavilion 15-cc023cl Motherboard Replacement: 步骤 15 中的图像 2,2
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 16 中的图像 1,1
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Motherboard Replacement: 步骤 17 中的图像 1,1
    • Disconnect SD and USB card cable.
结论
2等其他人完成本指南。
2条评论
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
richeydale67 - 回复
How can i get this model motherboard
Adeyinka Alasi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 1,409
