跳转到主内容
帮助
MacBook Pro 17" Unibody Right Clutch Hinge Replacement
Replace the right clutch hinge in your MacBook Pro 17" Unibody.
  • 作者: Walter Galan
  • 估计时间: 30分钟 - 2小时
  • 难度: 中等
Does your display have a hard time staying upright? Nobody likes a floppy display. Use this guide to replace the right clutch hinge.
步骤 1 Right Clutch Hinge  ¶
Remove the three 5.2 mm T6 Torx screws securing the right clutch hinge to the display assembly. Remove the three 5.2 mm T6 Torx screws securing the right clutch hinge to the display assembly.
  • Remove the three 5.2 mm T6 Torx screws securing the right clutch hinge to the display assembly.
步骤 2  ¶
Remove the right cltuch hinge from the display assembly.
步骤 2  ¶
  • Remove the right cltuch hinge from the display assembly.
  • Remove the plastic hinge guard as well, making sure to not lose it.
