跳转到主内容
帮助
Essential Phone Teardown
拆解
拆解
拆解提供窥探device内部的机会,不应该被用来作为拆卸说明。
There’s a newbie in the smartphone scene, and it’s bringing a whole lot less to the table. That’s right, in a world of "more is better," this phone has just the essentials—like a ceramic back, and a titanium chassis. Okay, it might actually be a little fancier than the name suggests—but we’ll have to open it up to find out for sure! Join us as we tear down the Essential Phone.
Teardowns are an essential part of the gadget world, so make sure to follow us on Facebook, Instagram, or Twitter for all of the necessary teardown and repair news.
工具 (接上)
步骤 1 Essential Phone Teardown  ¶
Here are the Essential Phone's essentials: Qualcomm Snapdragon 835 containing a Kryo 280 Octa-core CPU and an Adreno 540 GPU, paired with 4 GB RAM 128 GB UFS 2.1 onboard storage
  • Here are the Essential Phone's essentials:
  • Qualcomm Snapdragon 835 containing a Kryo 280 Octa-core CPU and an Adreno 540 GPU, paired with 4 GB RAM
  • 128 GB UFS 2.1 onboard storage
  • 5.71" LCD with 2560 × 1312 resolution (504 ppi)
  • Dual 13-megapixel rear cameras (one RGB + one monochrome) with image fusion technology
  • Front-facing camera with 8 MP resolution and 16:9 aspect ratio
  • 802.11a/b/g/n/ac Wi‑Fi + MIMO Bluetooth 5.0 LE + NFC
步骤 2  ¶
In their quest for a bezel-less screen, Essential managed to carve out some space for a front-facing camera and a nigh-invisible slit for the earpiece speaker. Around back, we find this phone's party trick—two power pins with built-in magnetic alignment. This is where the unessentials can latch on to the Essential Phone. While more are promised, as of now a 360° camera is the only accessory available from Essential.
步骤 2  ¶
  • In their quest for a bezel-less screen, Essential managed to carve out some space for a front-facing camera and a nigh-invisible slit for the earpiece speaker.
  • Around back, we find this phone's party trick—two power pins with built-in magnetic alignment. This is where the unessentials can latch on to the Essential Phone. While more are promised, as of now a 360° camera is the only accessory available from Essential.
  • Modular smartphone systems have yet to take off, but it's an idea we can appreciate—the environmental toll of clipping on a hot new camera module is a lot lower than upgrading your whole phone because the camera got "old."
  • We also spot a built-in dual camera system for those looking for good ol' ~180° photos, plus the fingerprint sensor responsible for securing the Essential's essentials.
步骤 3  ¶
Essential deemed a headphone jack unessential, providing just a USB-C connector instead. Risky. Flanking the connector are the speaker grill, SIM card slot, and lower microphone.  Just like in the Galaxy S8, the SIM eject and microphone holes seem a little too similar for comfort.
步骤 3  ¶
  • Essential deemed a headphone jack unessential, providing just a USB-C connector instead. Risky.
  • Flanking the connector are the speaker grill, SIM card slot, and lower microphone. Just like in the Galaxy S8, the SIM eject and microphone holes seem a little too similar for comfort.
  • ...and it proved to be an issue.
  • Essential left us a little surprise under the SIM card. With a totally blank and unbranded exterior, they hid all the identifying marks inside on a cute little tag.
  • We're amused to find that it doesn't come out all the way. Did Essential assemble the phone around this little tag?
步骤 4  ¶
It's past time to peek inside, but we're having no luck getting in. With no visible screws, we can only assume it's assembled with glue—but ever-increasing amounts of heat and suction haven't helped weaken this phone's hold on the display. In desperation, we reverse polarity and try some Super Cold. After a harrowing arctic expedition, it's the back cover that finally loosens first, revealing...
步骤 4  ¶
  • It's past time to peek inside, but we're having no luck getting in. With no visible screws, we can only assume it's assembled with glue—but ever-increasing amounts of heat and suction haven't helped weaken this phone's hold on the display.
  • In desperation, we reverse polarity and try some Super Cold.
  • After a harrowing arctic expedition, it's the back cover that finally loosens first, revealing...
  • ...Nothing! Beneath the giant glue pad, we find only the wrong ends of a couple screws and a midframe assembly.
步骤 5  ¶
We stay frosty, now more determined than ever to peel up the frozen LCD panel while dealing with the fallout from previous prying attempts. Looks like we have a different definition of essential than Essential does—our Essential Electronics Tool Kit, designed to tackle all common electronics repairs, wasn't enough to crack this nut of a phone. Some intense reinforcements were necessary. Even after peeling up the LCD panel, the interior continues to be well-guarded. After all that work, all we have to show for it is a busted display, a blank midframe shield, and a stray IC on the back of the display:
步骤 5  ¶
  • We stay frosty, now more determined than ever to peel up the frozen LCD panel while dealing with the fallout from previous prying attempts.
  • Looks like we have a different definition of essential than Essential does—our Essential Electronics Tool Kit, designed to tackle all common electronics repairs, wasn't enough to crack this nut of a phone. Some intense reinforcements were necessary.
  • Even after peeling up the LCD panel, the interior continues to be well-guarded. After all that work, all we have to show for it is a busted display, a blank midframe shield, and a stray IC on the back of the display:
  • Qualcomm QTC800S
  • The cover glass separates from the LCD panel rather easily. That could be good if you just wanted to swap out some cracked glass, but the challenging opening procedure makes that prospect somewhat dubious.
步骤 6  ¶
After the unexpectedly difficult journey through the outside of the phone, we lift the midframe shield to finally reveal some internal components. We spy: a heat pipe, a bunch of grounding fingers, and a battery with stretch-release adhesive ... that's trapped under another bracket. Credit where credit is due: stretch-release adhesive is the most repair-friendly adhesive, and we wish more manufacturers would adopt it. Unfortunately it's kind of wasted on a phone that's this hard to get into.
步骤 6  ¶
  • After the unexpectedly difficult journey through the outside of the phone, we lift the midframe shield to finally reveal some internal components.
  • We spy: a heat pipe, a bunch of grounding fingers, and a battery with stretch-release adhesive ... that's trapped under another bracket.
  • Credit where credit is due: stretch-release adhesive is the most repair-friendly adhesive, and we wish more manufacturers would adopt it. Unfortunately it's kind of wasted on a phone that's this hard to get into.
  • The battery claims an 11.70 Wh capacity—not too shabby when compared with the Galaxy S8 at 11.55 Wh, the iPhone 7 at 7.45 Wh, or the OnePlus5 at 12.35 Wh.
步骤 7  ¶
That little mattress tag we found in the SIM slot removes quite easily from this side. It does indeed look like the phone was assembled with this little guy comfortably in place. Meanwhile, we remove the massive motherboard, including its peninsular (Floridian?) charging port protuberance. The USB-C port is soldered straight to the motherboard. We are disappointed. If you need to replace this high-wear component, you're in for an (expensive) microsoldering job or a (very expensive) full-motherboard replacement.
步骤 7  ¶
  • That little mattress tag we found in the SIM slot removes quite easily from this side. It does indeed look like the phone was assembled with this little guy comfortably in place.
  • Meanwhile, we remove the massive motherboard, including its peninsular (Floridian?) charging port protuberance. The USB-C port is soldered straight to the motherboard. We are disappointed.
  • If you need to replace this high-wear component, you're in for an (expensive) microsoldering job or a (very expensive) full-motherboard replacement.
  • Speaking of removing the board...
  • The backside of the motherboard is snaked with antenna interconnect cables and vacant coaxial connectors.
步骤 8  ¶
Qualcomm released a development kit for the Snapdragon 835 showing us some silicon to expect. The chips we find are:
步骤 8  ¶
步骤 9  ¶
And for the backside:
步骤 9  ¶
  • And for the backside:
  • Qorvo QM78012 RF fusion LB module
  • Skyworks Solutions 77360-2 power amplifier module
  • Avago AFEM-9046 and AFEM-9036 IC's
  • Qualcomm PM8998 (similar to PM8920)
  • NXP Semiconductors TFA9891 audio amplifier
  • Qualcomm SMB1381 power management IC
步骤 10  ¶
And the rest of the chips:
步骤 10  ¶
  • And the rest of the chips:
  • PM8005 power management IC
  • SiBeam SB6212CZU Snap wireless connector IC
  • Fresco Logic FL1100-1A0-LX USB 3.0 host controller
步骤 11  ¶
With the motherboard on ice, we're finally able to tweeze out the dual camera module. Either Essential accidentally put these camera pop connectors on backwards, or someone had too much fun figuring how to origami them into place. Nearby, the selfie cam lies on a strip of glue and takes a little more work to extract, bringing the front-facing sensor cable along for the ride.
步骤 11  ¶
  • With the motherboard on ice, we're finally able to tweeze out the dual camera module.
  • Either Essential accidentally put these camera pop connectors on backwards, or someone had too much fun figuring how to origami them into place.
  • Nearby, the selfie cam lies on a strip of glue and takes a little more work to extract, bringing the front-facing sensor cable along for the ride.
  • Surprise! The front-facing camera and earpiece speaker come as a single part. That tiny port lines up directly with the über-slim grille at the top of the phone!
步骤 12  ¶
De-capping (literally, it looks like a cap) the vibrator, we're surprised there's no rubber dampener between these pieces. The vibrator appears to be a standard pancake style cell motor, albeit a little taller than the usual short-stack. Among the final components out: the sprawling loudspeaker and accompanying contact cable.
步骤 12  ¶
  • De-capping (literally, it looks like a cap) the vibrator, we're surprised there's no rubber dampener between these pieces.
  • The vibrator appears to be a standard pancake style cell motor, albeit a little taller than the usual short-stack.
  • Among the final components out: the sprawling loudspeaker and accompanying contact cable.
  • With its odd shape, the speaker kinda looks like it was designed to fill all unclaimed real estate in the phone body.
步骤 13  ¶
Magnets for those modular clip-on accessories are neatly labeled. They'd be tough to replace, but that's okay—you're likely to be rocking a different phone by the time they start to wear out in 700 years or so. Not much remains besides the fingerprint sensor, glued comfortably in place on the back—a location that comes with some drawbacks, but is quickly becoming the de facto smartphone standard. Well, sort of. Not much remains besides the fingerprint sensor, glued comfortably in place on the back—a location that comes with some drawbacks, but is quickly becoming the de facto smartphone standard. Well, sort of.
步骤 13  ¶
  • Magnets for those modular clip-on accessories are neatly labeled. They'd be tough to replace, but that's okay—you're likely to be rocking a different phone by the time they start to wear out in 700 years or so.
  • Not much remains besides the fingerprint sensor, glued comfortably in place on the back—a location that comes with some drawbacks, but is quickly becoming the de facto smartphone standard. Well, sort of.
步骤 14  ¶
For promising just the essentials, the Essential Phone took a lot more out of us than expected. It also took a lot more Super Cold than expected...
步骤 14  ¶
  • For promising just the essentials, the Essential Phone took a lot more out of us than expected. It also took a lot more Super Cold than expected...
  • Enjoy this layout shot while we grab the winter coats from our closet and defrost the teardown room.
步骤 15 Final Thoughts  ¶
Essential Phone Repairability Score: 1 out of 10 (10 is easiest to repair)
  • Essential Phone Repairability Score: 1 out of 10 (10 is easiest to repair)
  • To the extent that screws are used, they are all standard Phillips/JIS fasteners.
  • The battery is secured with repair-friendly stretch-release adhesive. Too bad it's so inaccessible.
  • The USB-C port is soldered to the motherboard, and with no headphone jack it'll be subject to extra wear.
  • Nearly invisible seams and copious adhesive means any attempt at repair is likely to inflict as much damage as it fixes.
  • Did we mention we had to freeze it?
