跳转到主内容
帮助
Nexus One Motherboards Replacement
会员贡献的指南
会员贡献的指南
一位我们社区很棒的成员写出了本指南。它不是由 iFixit 工作人员管理。
This guide is for installing the upper and lower motherboards on the Nexus One.
  • 作者: Niklas Johnson
  • 估计时间: 45分钟 - 1小时
  • 难度: 中等
步骤 1 Motherboards  ¶
Insert the spudger under the connector. Push the spudger up and twist to release the connector.
步骤 1 Motherboards  ¶
  • Insert the spudger under the connector.
  • Push the spudger up and twist to release the connector.
  • Repeat for the next connector.
步骤 2  ¶
Push on the USB port to expose the black connector. Use the spudger to pry the connector upwards. Use the spudger to pry the connector upwards.
步骤 2  ¶
  • Push on the USB port to expose the black connector.
  • Use the spudger to pry the connector upwards.
步骤 3  ¶
Place the spugder under the antenna connector. Pry connector up vertically.
步骤 3  ¶
  • Place the spugder under the antenna connector.
  • Pry connector up vertically.
步骤 4  ¶
Insert the spudger into tab above the camera. Slide upwards until the board detaches from the case. Slide upwards until the board detaches from the case.
步骤 4  ¶
  • Insert the spudger into tab above the camera.
  • Slide upwards until the board detaches from the case.
步骤 5  ¶
Press the pointed tip of the spudger into the space below the button assembly.
步骤 5  ¶
  • Press the pointed tip of the spudger into the space below the button assembly.
  • Wiggle the spudger tip towards the outside of the button.
  • The button assembly is under some tension and may fly off.
步骤 6  ¶
Push the pointed tip of the spudger into the base of the side button board.
步骤 6  ¶
  • Push the pointed tip of the spudger into the base of the side button board.
  • Lift up, the board will disconnect from the case.
步骤 7  ¶
Push on the lower motherboard until it slides under the case support. The motherboard assembly comes out as a single piece. Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
步骤 7  ¶
  • Push on the lower motherboard until it slides under the case support.
  • The motherboard assembly comes out as a single piece.
  • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
