跳转到主内容
帮助
iPhone 7 Earpiece Speaker Replacement
Replace the earpiece speaker in an iPhone 7.
  • 作者: Evan Noronha
  • 估计时间: 20分钟 - 1小时
  • 难度: 中等
Are you having trouble hearing the other end of the phone line? It may be time to replace the earpiece speaker. Follow the steps in this guide to replace the earpiece speaker, which also functions as a secondary loudspeaker, in an iPhone 7.
步骤 1 Earpiece Speaker  ¶
Remove the three Phillips screws securing the earpiece bracket to the front panel:
  • Remove the three Phillips screws securing the earpiece bracket to the front panel:
  • Two 2.6 mm screws
  • One 1.7 mm screw
步骤 2  ¶
Remove the earpiece speaker bracket.
步骤 2  ¶
  • Remove the earpiece speaker bracket.
步骤 3  ¶
Lift the front facing camera out of the way to access the earpiece speaker. Lift the front facing camera out of the way to access the earpiece speaker.
步骤 3  ¶
  • Lift the front facing camera out of the way to access the earpiece speaker.
步骤 4  ¶
Remove the following two Phillips screws securing the earpiece speaker to the front panel:
步骤 4  ¶
  • Remove the following two Phillips screws securing the earpiece speaker to the front panel:
  • One 1.9 mm screw
  • One 2.5 mm screw
步骤 5  ¶
Remove the earpiece speaker.
步骤 5  ¶
  • Remove the earpiece speaker.
