跳转到主内容
帮助
Microtek ScanMaker 5900 Stepper Motor Replacement
需要更好的图片
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
标记错误
标记错误
本指南需要更好的标记。请帮助纠正或制作一些标记批注。
The purpose of this guide is to get the Y positioning slider to move. This is done so that the scanners lens's captures an interval of a surface instead of a point.
This guide will show you how to replace the scanners stepper motor.
步骤 1 Stepper Motor  ¶
Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left. Disconnect the white connector from the vertical standing circuit board.
  • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
  • Disconnect the white connector from the vertical standing circuit board.
步骤 2  ¶
Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place. The stepper motor will become loose, but not completely free. The stepper motor will become loose, but not completely free.
步骤 2  ¶
  • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
  • The stepper motor will become loose, but not completely free.
步骤 3  ¶
Using tweezers gently remove the tread from the black gear on the stepper motor. The stepper motor will become completely free. The stepper motor will become completely free.
步骤 3  ¶
  • Using tweezers gently remove the tread from the black gear on the stepper motor.
  • The stepper motor will become completely free.
