跳转到主内容
帮助
Canon AE-1 SLR Lens Mount Replacement
要点符号!
要点符号!
更好地协调标记与要点符号的颜色和类型将有助于使本指南更清楚!
需要更好的图片
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
This guide will demonstrate how to remove the SLR Lens Mount on the Canon AE-1.
  • 作者: Joe Blumberg
  • 估计时间: 5 - 10 分钟
  • 难度: 简单
This guide will teach the user how to remove a damaged SLR lens mount on the Cannon AE-1. The SLR lens mount allows the user to connect different lens to the Canon AE-1.
步骤 1 SLR Lens Mount  ¶
Remove the first set of two #00 phillips screws from the lens outer casing The first set of screws are located on the front and bottom of the lens casing
  • Remove the first set of two #00 phillips screws from the lens outer casing
  • The first set of screws are located on the front and bottom of the lens casing
  • Pull the screws out and set them aside so as not to lose them
步骤 2  ¶
Remove the remaining two #00 phillip screws from the lens outer casing The second set is located left and right side of the lens casing
步骤 2  ¶
  • Remove the remaining two #00 phillip screws from the lens outer casing
  • The second set is located left and right side of the lens casing
步骤 3  ¶
Once the screws have been taken out, you may simply remove the lens casing by pulling it away from the body of the camera.
步骤 3  ¶
  • Once the screws have been taken out, you may simply remove the lens casing by pulling it away from the body of the camera.
步骤 4  ¶
Remove the four #00 phillips screws from the SLR Lens Mount
步骤 4  ¶
  • Remove the four #00 phillips screws from the SLR Lens Mount
步骤 5  ¶
After the screws have been removed, pull the SLR Lens Mount away from the body of the camera Be aware that a pin will fall out when the SLR Lens Mount is removed. Be aware that a pin will fall out when the SLR Lens Mount is removed.
步骤 5  ¶
  • After the screws have been removed, pull the SLR Lens Mount away from the body of the camera
  • Be aware that a pin will fall out when the SLR Lens Mount is removed.
