跳转到主内容
帮助
Acer AL1916 Display Replacement
特色指南
特色指南
iFixit的工作人员认为该指南特别酷。
This guide will show the steps required to remove the back cover of the monitor, take out the malfunctioning display, and install the new display.
  • 作者: Keith
  • 估计时间: 30分钟 - 1小时
  • 难度: 中等
Replacing your display will give you a fresh new screen when your old one is not functioning properly.
工具
步骤 1 Display  ¶
Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply. Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
步骤 1 Display  ¶
  • Remove the three gold 7.5 mm Phillips #2 screws and one silver 8.3 mm Phillips #2 screw from the power supply.
步骤 2  ¶
Remove the two pieces of yellow tape on the left side of the power supply. Remove the two pieces of yellow tape on the left side of the power supply. Remove the two pieces of yellow tape on the left side of the power supply.
步骤 2  ¶
  • Remove the two pieces of yellow tape on the left side of the power supply.
步骤 3  ¶
Remove the four little white clips located underneath the pieces of tape by lifting up on their left side. Remove the four little white clips located underneath the pieces of tape by lifting up on their left side.
步骤 3  ¶
  • Remove the four little white clips located underneath the pieces of tape by lifting up on their left side.
步骤 4  ¶
With the needle-nose pliers, remove the four display connectors by pulling directly left. With the needle-nose pliers, remove the four display connectors by pulling directly left. With the needle-nose pliers, remove the four display connectors by pulling directly left.
步骤 4  ¶
  • With the needle-nose pliers, remove the four display connectors by pulling directly left.
步骤 5  ¶
Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor. Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor. Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor.
步骤 5  ¶
  • Remove the display cable located at the top of the circuit board by pulling it out towards the top of the monitor.
步骤 6  ¶
Turn the monitor on its side so that the power supply and circuit board are facing to the right Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total). Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total).
步骤 6  ¶
  • Turn the monitor on its side so that the power supply and circuit board are facing to the right
  • Remove the two 6.6 mm Phillips #2 screws located on both sides of the metal casing (four screws total).
步骤 7  ¶
Set the monitor back down so that the power supply and circuit board are facing you. Feed all four of the connector wires down through the metal casing.
步骤 7  ¶
  • Set the monitor back down so that the power supply and circuit board are facing you.
  • Feed all four of the connector wires down through the metal casing.
步骤 8  ¶
Grab the sides of the metal casing and lift up. Turn the display over to see the front; you are ready replace the broken display with a new one! Turn the display over to see the front; you are ready replace the broken display with a new one!
步骤 8  ¶
  • Grab the sides of the metal casing and lift up.
  • Turn the display over to see the front; you are ready replace the broken display with a new one!
