跳转到主内容
帮助
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Optical Drive Replacement
Upgrade or replace the SuperDrive (requires a slim drive) in your MacBook Pro 15" Core 2 Duo Models A1226 and A1260.
  • 作者: Walter Galan
  • 估计时间: 30分钟 - 1小时
  • 难度: 中等
Upgrade or replace the SuperDrive (requires a slim drive).
步骤 1 Optical Drive  ¶
If your new optical drive already has brackets on it, you'll only need to transfer the data cable to your new drive. Skip the bracket removal steps below. Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
  • If your new optical drive already has brackets on it, you'll only need to transfer the data cable to your new drive. Skip the bracket removal steps below.
  • Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
  • Rotate the drive and disconnect the orange ribbon cable from the optical drive.
步骤 2  ¶
Remove the two Phillips screws securing the mounting bracket to the rear of the optical drive.
步骤 2  ¶
  • Remove the two Phillips screws securing the mounting bracket to the rear of the optical drive.
步骤 3  ¶
Rotate the drive and remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
步骤 3  ¶
  • Rotate the drive and remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
