跳转到主内容
帮助
Canon Powershot S200 Flash Unit Replacement
需要更好的图片
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
要点符号!
要点符号!
更好地协调标记与要点符号的颜色和类型将有助于使本指南更清楚!
会员贡献的指南
会员贡献的指南
一位我们社区很棒的成员写出了本指南。它不是由 iFixit 工作人员管理。
This guide will provide the necessary steps needed for disassembling the camera's flash unit.
  • 作者: Tanya
  • 估计时间: 30 - 40 分钟
  • 难度: 困难
The flash unit provides necessary lighting when not enough is available.
步骤 1 Flash Unit  ¶
Remove the 3.3 mm screw from underneath the clear plastic flash unit on the front side.
步骤 1 Flash Unit  ¶
  • Remove the 3.3 mm screw from underneath the clear plastic flash unit on the front side.
步骤 2  ¶
Remove the 3.4mm screw from the top of the flash unit and housing plate.
步骤 2  ¶
  • Remove the 3.4mm screw from the top of the flash unit and housing plate.
步骤 3  ¶
Remove the 2.1mm screw from the interlocking clip on the right. Remove the 2.1mm screw from the interlocking clip on the right.
步骤 3  ¶
  • Remove the 2.1mm screw from the interlocking clip on the right.
步骤 4  ¶
Pull the flash unit away from the interlocking clip on the housing plate. This will require some maneuvering to free the interlocking clip from the housing plate.
步骤 4  ¶
  • Pull the flash unit away from the interlocking clip on the housing plate.
  • This will require some maneuvering to free the interlocking clip from the housing plate.
步骤 5  ¶
Slide the flash unit to the left and away from the housing plate. Slide the flash unit to the left and away from the housing plate.
步骤 5  ¶
  • Slide the flash unit to the left and away from the housing plate.
步骤 6  ¶
Unsolder the pink wire from the condenser.
步骤 6  ¶
  • Unsolder the pink wire from the condenser.
步骤 7  ¶
Remove the clear plastic cover from the white wire by lifting off with finger. Desolder the white wire.
步骤 7  ¶
  • Remove the clear plastic cover from the white wire by lifting off with finger.
  • Desolder the white wire.
步骤 8  ¶
Remove the gray wire by  desoldering it from the underside of the flash unit.
步骤 8  ¶
  • Remove the gray wire by desoldering it from the underside of the flash unit.
步骤 9  ¶
Carefully pull the flash unit off the condenser. There is tape underneath, so some force may be required.
步骤 9  ¶
  • Carefully pull the flash unit off the condenser. There is tape underneath, so some force may be required.
