跳转到主内容
帮助
Samsung Fascinate Motherboard Replacement
动态照片拍摄
动态照片拍摄
成为一个动作片主人公!本指南需要一些图片,这些图片能够更好演示如何进行某些特定操作。
需要更好的图片
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
要点符号!
要点符号!
更好地协调标记与要点符号的颜色和类型将有助于使本指南更清楚!
Installing the motherboard of the Samsung Galaxy S.
This guide will show you how to get access to the motherboard of the Samsung Galaxy S so that you can remove and/or replace it.
步骤 1 Motherboard  ¶
Use the plastic opening tool to disconnect the white wire boxed in red. Carefully disconnect the green and golden boxed components from the motherboard. The boxed components do not completely detached from the motherboard.
步骤 1 Motherboard  ¶
  • Use the plastic opening tool to disconnect the white wire boxed in red.
  • Carefully disconnect the green and golden boxed components from the motherboard.
  • The boxed components do not completely detached from the motherboard.
步骤 2  ¶
Use the screwdriver to remove the black screw circled in blue. Lift the motherboard off of the touchscreen. The motherboard is still attached to the phone by wires. Do not pull on the wires.
步骤 2  ¶
  • Use the screwdriver to remove the black screw circled in blue.
  • Lift the motherboard off of the touchscreen.
  • The motherboard is still attached to the phone by wires. Do not pull on the wires.
步骤 3  ¶
Using the plastic opening tool, gently pry the silver cylinder out of its housing. The cylinder is held in place by a weak adhesive and shouldn't be too difficult to remove. The cylinder is held in place by a weak adhesive and shouldn't be too difficult to remove.
步骤 3  ¶
  • Using the plastic opening tool, gently pry the silver cylinder out of its housing.
  • The cylinder is held in place by a weak adhesive and shouldn't be too difficult to remove.
