跳转到主内容
帮助
Nikon Coolpix P4 Motherboard Replacement
要点符号!
要点符号!
更好地协调标记与要点符号的颜色和类型将有助于使本指南更清楚!
标记错误
标记错误
本指南需要更好的标记。请帮助纠正或制作一些标记批注。
Replacing the Motherboard.
  • 作者: Luke Baumann
  • 估计时间: 10分钟
  • 难度: 中等
This guide will tell you how to replace your motherboard
步骤 1 Motherboard  ¶
Remove the screw to the right of the flash.
步骤 1 Motherboard  ¶
  • Remove the screw to the right of the flash.
  • Remove the screw to the right of the microphone on the bottom. (0.124in)
步骤 2  ¶
Remove the two screws on the right side of the camera. (0.115 in screws)
步骤 2  ¶
  • Remove the two screws on the right side of the camera. (0.115 in screws)
步骤 3  ¶
Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
步骤 3  ¶
  • Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
步骤 4  ¶
Remove the 7 screws from the back of the camera. (0.111 in screws)
步骤 4  ¶
  • Remove the 7 screws from the back of the camera. (0.111 in screws)
步骤 5  ¶
Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
步骤 5  ¶
  • Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
步骤 6  ¶
Remove the right panel.
步骤 6  ¶
  • Remove the right panel.
步骤 7  ¶
Remove the screw from the top of the camera. (0.112 in screws)
步骤 7  ¶
  • Remove the screw from the top of the camera. (0.112 in screws)
步骤 8  ¶
Remove the three screws from the motherboard. (0.112 in screws)
步骤 8  ¶
  • Remove the three screws from the motherboard. (0.112 in screws)
  • Detach the orange tab with the foam on top. It will click out of place.
步骤 9  ¶
Remove the motherboard by pulling it up, out of the port.
步骤 9  ¶
  • Remove the motherboard by pulling it up, out of the port.
步骤 10  ¶
Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
步骤 10  ¶
  • Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
  • Be careful when removing the connector.
步骤 11  ¶
Remove the motherboard from camera body.
步骤 11  ¶
  • Remove the motherboard from camera body.
  • Replace with a new motherboard and follow the steps in reverse order to reassemble.
