跳转到主内容
帮助
Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement
This guide will aid you in removing the CD/DVD Drive from the system.
步骤 1 CD/DVD Drive  ¶
Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
步骤 1 CD/DVD Drive  ¶
  • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
步骤 2  ¶
Locate and remove the circled screw with a Phillips #0 screwdriver. Locate and remove the circled screw with a Phillips #0 screwdriver.
步骤 2  ¶
  • Locate and remove the circled screw with a Phillips #0 screwdriver.
步骤 3  ¶
Use the plastic opening tool to pry the CD/DVD drive out of the frame.
步骤 3  ¶
  • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
步骤 4  ¶
Gently remove the CD/DVD drive from the laptop body.
步骤 4  ¶
  • Gently remove the CD/DVD drive from the laptop body.
