跳转到主内容
帮助
Disassembling HP Photosmart D110a Printer Hood
动态照片拍摄
动态照片拍摄
成为一个动作片主人公!本指南需要一些图片,这些图片能够更好演示如何进行某些特定操作。
步骤精简
步骤精简
本指南有一些不必要的步骤。请进行精简以使该指南更简洁 !
Disassembling the printer's hood will give access to the interior parts.
Disassembling the printer is relatively simple, and involving only one screw being removed and some cables being unplugged.
步骤 1 Disassembling HP Photosmart D110a Printer Hood  ¶
After being separated from the printer, the hood is ready to be disassembled. Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver. Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
  • After being separated from the printer, the hood is ready to be disassembled.
  • Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
步骤 2  ¶
With the screw removed, separate the two pieces of the hood by lifting it vertically. Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
步骤 2  ¶
  • With the screw removed, separate the two pieces of the hood by lifting it vertically.
  • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
  • Carefully pull down the white ribbon cable through the top piece of the hood.
步骤 3  ¶
Carefully separate the two hood pieces connected by the black ribbon. Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
步骤 3  ¶
  • Carefully separate the two hood pieces connected by the black ribbon.
  • Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
  • The printer hood should now be in 2 pieces.
