跳转到主内容
帮助
iMac Intel 24" EMC 2111 Right Speaker Replacement
Replace a blown right speaker in your iMac Intel 24" EMC 2111.
Use this guide to replace a blown right speaker.
步骤 1 Right Speaker  ¶
Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac. Peel the tape away from the lower corner of the right speaker.
  • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
  • Peel the tape away from the lower corner of the right speaker.
步骤 2  ¶
De-route the right-hand speaker's cable from between the logic board and the optical drive fan. Disconnect the cable from the logic board.
步骤 2  ¶
  • De-route the right-hand speaker's cable from between the logic board and the optical drive fan.
  • Disconnect the cable from the logic board.
步骤 3  ¶
Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
步骤 3  ¶
  • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
步骤 4  ¶
Pull the right speaker away from the logic board and remove it from the iMac.
步骤 4  ¶
  • Pull the right speaker away from the logic board and remove it from the iMac.
