跳转到主内容
帮助
iPod Nano 2nd Generation Battery Replacement
特色指南
特色指南
iFixit的工作人员认为该指南特别酷。
  • 作者: iRobot
  • 估计时间: 45分钟 - 2小时
  • 难度: 非常困难
Battery not lasting long? Swap it out (requires soldering).
步骤 1 Battery  ¶
Use a spudger to scrape away the black glue covering the three battery wires.
步骤 1 Battery  ¶
  • Use a spudger to scrape away the black glue covering the three battery wires.
步骤 2  ¶
Peel up the orange tape covering the three solder points on the other side of the logic board.
步骤 2  ¶
  • Peel up the orange tape covering the three solder points on the other side of the logic board.
步骤 3  ¶
Place the desoldering wick on top of the existing solder ball.
步骤 3  ¶
  • Place the desoldering wick on top of the existing solder ball.
  • Place the soldering iron on top of wick above the existing solder ball.
  • Hold the soldering iron in place until the solder melts into the wick.
  • Repeat the same procedure on the remaining two connectors.
步骤 4  ¶
Be careful not to scrape the metal rings surrounding the connectors off the logic board. If you accidentally scrape these off, you won't be able to reconnect the replacement battery.
步骤 4  ¶
  • Be careful not to scrape the metal rings surrounding the connectors off the logic board. If you accidentally scrape these off, you won't be able to reconnect the replacement battery.
  • Use a metal spudger to carefully straighten the battery wires. Be sure to only touch one contact at a time.
步骤 5  ¶
Pull the battery wires through the logic board to free the battery. If the wires don't easily come free, make sure the wires are straight and all the solder has been removed.
步骤 5  ¶
  • Pull the battery wires through the logic board to free the battery. If the wires don't easily come free, make sure the wires are straight and all the solder has been removed.
  • Slide the three wires of the replacement battery through the holes in the logic board. Going from the edge of the iPod, the order of wires is black, red, white.
步骤 6  ¶
Bend the wires over to prevent them from sliding out of the logic board.
步骤 6  ¶
  • Bend the wires over to prevent them from sliding out of the logic board.
步骤 7  ¶
Place the soldering iron onto the battery wire and metal connector for one to two seconds to heat them up.
步骤 7  ¶
  • Place the soldering iron onto the battery wire and metal connector for one to two seconds to heat them up.
  • Add the solder wire and wait for the solder to melt onto the wire. Once a small bead has formed around the wire, lift the solder away first and then remove the soldering iron.
  • Continue with the other two connections the same way, taking special care not to solder two of the connectors together.
