跳转到主内容
帮助
HP Envy 17-3070NR Top Cover Replacement
不正确的工具
不正确的工具
通过在图片或文字中使用正确的工具来帮助完善该指南
更好的介绍
更好的介绍
通过完成或修改其开头介绍以改善本指南。
Replace the top cover.
步骤 1 Top Cover  ¶
Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right. Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right. Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right.
步骤 1 Top Cover  ¶
  • Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right.
步骤 2  ¶
Remove the second connector by gently pulling upward. Remove the second connector by gently pulling upward. Remove the second connector by gently pulling upward.
步骤 2  ¶
  • Remove the second connector by gently pulling upward.
步骤 3  ¶
Remove the seventeen 6.6mm Phillips screws.
步骤 3  ¶
  • Remove the seventeen 6.6mm Phillips screws.
  • Remove the three 3.6 mm Phillips screws.
  • Remove the eleven 3.2mm Phillips screws
  • Three of the 3.2mm Phillips screws are located underneath the black hard drive flap.
  • Make sure that you keep the screws organized so that you keep track of all of the different sizes and locations.
步骤 4  ¶
Flip the laptop over. Use a Plastic Opening tool to carefully pry all around the top cover up off of the remaining assembly. Starting location for prying does not matter as long as you pry all around the frame before lifting it off.
步骤 4  ¶
  • Flip the laptop over.
  • Use a Plastic Opening tool to carefully pry all around the top cover up off of the remaining assembly.
  • Starting location for prying does not matter as long as you pry all around the frame before lifting it off.
  • Do not fully lift the top cover because there are cables that will need to be disconnected before removal.
步骤 5  ¶
Gently pull the white connector shown in the picture towards you to disconnect it from the system board. Gently pull the white connector shown in the picture towards you to disconnect it from the system board.
步骤 5  ¶
  • Gently pull the white connector shown in the picture towards you to disconnect it from the system board.
步骤 6  ¶
Gently pull the black connector towards you to disconnect the top cover from the main assembly.
步骤 6  ¶
  • Gently pull the black connector towards you to disconnect the top cover from the main assembly.
  • Once both connectors are disconnected, lift the top cover off of the main assembly.
