跳转到主内容
帮助
Iomega Z100S2 Disk Reader Replacement
特色指南
特色指南
iFixit的工作人员认为该指南特别酷。
Installing the disk reader.
  • 作者: Ezery Kennedy
  • 估计时间: 5 - 7 分钟
  • 难度: 简单
工具
步骤 1 Disk Reader  ¶
Unhook the two springs from the front plastic hooks. The black side rails of the reader should easily slide forward and off.
步骤 1 Disk Reader  ¶
  • Unhook the two springs from the front plastic hooks.
  • The black side rails of the reader should easily slide forward and off.
步骤 2  ¶
There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
步骤 2  ¶
  • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
  • The tab does not come completely out, it only slides up slightly, so don't rip it out!
步骤 3  ¶
Grab the reader by its sides and gently pull it upward. There are two wires still connected to the bottom of the reader that haven't been detached.
步骤 3  ¶
  • Grab the reader by its sides and gently pull it upward.
  • There are two wires still connected to the bottom of the reader that haven't been detached.
步骤 4  ¶
Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
步骤 4  ¶
  • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
步骤 5  ¶
Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you. Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
步骤 5  ¶
  • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
步骤 6  ¶
Lift the reader up and out from the device.
步骤 6  ¶
  • Lift the reader up and out from the device.
