跳转到主内容
帮助
Canon PowerShot SD850 IS Flash Unit Replacement
动态照片拍摄
动态照片拍摄
成为一个动作片主人公!本指南需要一些图片,这些图片能够更好演示如何进行某些特定操作。
不一致的图片
不一致的图片
更新这个指南上的图片以和先决条件帖里的一致会使这份指南增加魅力。
缺少前提条件
缺少前提条件
本指南缺少关于如何开始这些步骤的信息。请编写前提指南!
缺失步骤
缺失步骤
糟糕!本指南目前缺少一些重要的步骤。
  • 作者: Peter Tran
  • 估计时间: 25 - 35 分钟
  • 难度: 中等
Use this guide to remove a broken flash unit from your Canon PowerShot SD850 IS.
工具
步骤 1 Flash Unit  ¶
Remove the 1.85 mm #00 Phillips located on the left side of the camera.
步骤 1 Flash Unit  ¶
  • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
步骤 2  ¶
Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit. Next use the tweezers to carefully remove the speaker cable off its respective holders.
步骤 2  ¶
  • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
  • Next use the tweezers to carefully remove the speaker cable off its respective holders.
步骤 3  ¶
Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
步骤 3  ¶
  • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
步骤 4  ¶
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable.  The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure).  For the yellow one, apply pressure horizontally. Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
步骤 4  ¶
  • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
  • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
步骤 5  ¶
Gently remove the flash component from the rest of the camera.
步骤 5  ¶
  • Gently remove the flash component from the rest of the camera.
  • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
  • The flash unit can now be removed and replaced.
  • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
