跳转到主内容
帮助
MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Cable Replacment
Replaces the cable that connects the upper case, power button, trackpad, sleep sensor, bluetooth board, and keyboard to the logic board.
  • 作者: Matt Barnes
  • 估计时间: 30 - 45 分钟
  • 难度: 中等
步骤 1 Upper Case Cable Replacment  ¶
Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
  • Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
步骤 2  ¶
Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
步骤 2  ¶
  • Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
步骤 3  ¶
Slide the orange keyboard backlight ribbon out of its connector.
步骤 3  ¶
  • Slide the orange keyboard backlight ribbon out of its connector.
步骤 4  ¶
Peel up the orange tape covering the keyboard backlight connector.
步骤 4  ¶
  • Peel up the orange tape covering the keyboard backlight connector.
步骤 5  ¶
Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
步骤 5  ¶
  • Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
步骤 6  ¶
Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
步骤 6  ¶
  • Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
步骤 7  ¶
Disconnect the power button cable, the bluetooth cable, and the sleep sensor cable.
步骤 7  ¶
  • Disconnect the power button cable, the bluetooth cable, and the sleep sensor cable.
  • Carefully peel up the orange ribbon cable removing tape as necessary.
