跳转到主内容
帮助
iPad Mini 3 Wi-Fi Battery Replacement
Replace a faulty battery in an iPad Mini 3 Wi-Fi.
  • 作者: Sam Goldheart
  • 估计时间: 2 - 3 小时
  • 难度: 困难
Use this guide to remove and replace the battery in your iPad Mini 3 Wi-Fi.
If your battery is swollen, take appropriate precautions.
步骤 1 Battery  ¶
The battery is held to the iPad case with some adhesive that will need to be heated in order to be separated. Heat an iOpener and place it in the center of the back of the iPad case.
步骤 1 Battery  ¶
  • The battery is held to the iPad case with some adhesive that will need to be heated in order to be separated.
  • Heat an iOpener and place it in the center of the back of the iPad case.
  • After about two minutes, remove the iOpener and place it on the right side of the iPad—the side farthest from the camera.
步骤 2  ¶
Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals. Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
步骤 2  ¶
  • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
  • Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
  • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
步骤 3  ¶
Remove the plastic card and insert it under the battery cell nearest the edge of the case. Remove the plastic card and insert it under the battery cell nearest the edge of the case.
步骤 3  ¶
  • Remove the plastic card and insert it under the battery cell nearest the edge of the case.
步骤 4  ¶
Insert a second plastic card beneath the battery cell on the logic board side near the front-facing camera. Insert a second plastic card beneath the battery cell on the logic board side near the front-facing camera.
步骤 4  ¶
  • Insert a second plastic card beneath the battery cell on the logic board side near the front-facing camera.
步骤 5  ¶
Remove and insert the second card under the battery near the headphone jack. Remove and insert the second card under the battery near the headphone jack.
步骤 5  ¶
  • Remove and insert the second card under the battery near the headphone jack.
步骤 6  ¶
Grasp both cards and slowly pull the case-side battery cell up about two inches from the rear case. Peel slowly and try not to bend the battery cell.
步骤 6  ¶
  • Grasp both cards and slowly pull the case-side battery cell up about two inches from the rear case.
  • Peel slowly and try not to bend the battery cell.
步骤 7  ¶
Move the right-hand card up under the other battery cell. Move the right-hand card up under the other battery cell.
步骤 7  ¶
  • Move the right-hand card up under the other battery cell.
步骤 8  ¶
Move the left-hand card up under the other battery cell. Move the left-hand card up under the other battery cell.
步骤 8  ¶
  • Move the left-hand card up under the other battery cell.
步骤 9  ¶
Grip both cards and use them to lift the battery from the rear case. Remove the battery from the iPad. Remove the battery from the iPad.
步骤 9  ¶
  • Grip both cards and use them to lift the battery from the rear case.
  • Remove the battery from the iPad.
