跳转到主内容
帮助
iPad 3G Logic Board Replacement
Replace a burned out logic board on your iPad 3G.
Use this guide to replace your iPad 3G's logic board.
步骤 1 Logic Board  ¶
Carefully peel back the rubber EMI shield covering the GPS antenna socket.
步骤 1 Logic Board  ¶
  • Carefully peel back the rubber EMI shield covering the GPS antenna socket.
  • Use the edge of an iPod opening tool to flip up the GPS ribbon cable retaining flap attached to the GPS cable's socket on the logic board.
  • Be sure you pry up on the retaining flap, not the socket itself.
步骤 2  ¶
Pull the GPS antenna ribbon cable out of its socket.
步骤 2  ¶
  • Pull the GPS antenna ribbon cable out of its socket.
步骤 3  ¶
Use the edge of an iPod opening tool to pry up the retaining flap on the headphone jack/microphone socket. Be sure you pry up on the retaining flap, not the socket itself.
步骤 3  ¶
  • Use the edge of an iPod opening tool to pry up the retaining flap on the headphone jack/microphone socket.
  • Pull the headphone jack/microphone ribbon cable out of its socket.
  • Pull the cable toward the left side of the iPad.
步骤 4  ¶
Use an iPod opening tool to pry the SIM board connector up off its socket on the logic board.
步骤 4  ¶
  • Use an iPod opening tool to pry the SIM board connector up off its socket on the logic board.
  • This connector might be covered with black tape. Use tweezers to remove the tape before prying.
步骤 5  ¶
Fold the SIM cable toward the bottom of the iPad to access the speaker connector.
步骤 5  ¶
  • Fold the SIM cable toward the bottom of the iPad to access the speaker connector.
  • Use the edge of an iPod opening tool to pry the speaker connector up and out of its socket on the logic board.
  • Pry up from beneath the wires.
步骤 6  ¶
Remove the following screws securing the logic board to the rear panel assembly.
步骤 6  ¶
  • Remove the following screws securing the logic board to the rear panel assembly.
  • Two 4.56 mm T5 Torx screws.
  • Two 3.76 mm T5 Torx screws.
步骤 7  ¶
Use the edge of an iPod opening tool to carefully pry the dock cable connector straight up off the logic board.
步骤 7  ¶
  • Use the edge of an iPod opening tool to carefully pry the dock cable connector straight up off the logic board.
步骤 8  ¶
Lift the logic board out of the rear panel assembly.
步骤 8  ¶
  • Lift the logic board out of the rear panel assembly.
