跳转到主内容
帮助
PowerBook G4 Aluminum 12" 1-1.5 GHz LCD panel upgrade
会员贡献的指南
会员贡献的指南
一位我们社区很棒的成员写出了本指南。它不是由 iFixit 工作人员管理。
Upgrade a 1400x1050 LCD panel.
  • 作者: Terrance
  • 估计时间: 2 - 4 小时
  • 难度: 非常困难
The original LCD 1024x768 resolution is kinda low. This guide will show you how to fit HV121P01-100 or 101 into PowerBook G4 12".
步骤 1 LCD panel upgrade  ¶
Some HV121P01 are IBM/Lenovo/Thinkpad parts. Comes with Wacom Digitizer and front shield. Remove the Wacom Digitizer first. 1. remove the 4 philips screws in red circles. 2. use some thin object, like a knife, to separate the 2 double sided tapes in red rectangles from the white plastic back.
  • Some HV121P01 are IBM/Lenovo/Thinkpad parts. Comes with Wacom Digitizer and front shield. Remove the Wacom Digitizer first.
  • 1. remove the 4 philips screws in red circles.
  • 2. use some thin object, like a knife, to separate the 2 double sided tapes in red rectangles from the white plastic back.
  • The front shield can protect the screen during the following steps, remove it only after anything else are done!
步骤 2  ¶
Lift 2 ends of tape,at the CCFL side, and remove 2 black philips screws in the red circles. Remove the 2 small metal parts in the red rectangles. Remove the 2 small metal parts in the red rectangles.
步骤 2  ¶
  • Lift 2 ends of tape,at the CCFL side, and remove 2 black philips screws in the red circles.
  • Remove the 2 small metal parts in the red rectangles.
步骤 3  ¶
You need to extend the CCFL High Voltage cable, if it is not long enough to reach the inverter. You'd better get a electronics friend to help you. Should be very easy for him. If it's done wrong. Leakage or shock may happen.
步骤 3  ¶
  • You need to extend the CCFL High Voltage cable, if it is not long enough to reach the inverter. You'd better get a electronics friend to help you. Should be very easy for him. If it's done wrong. Leakage or shock may happen.
  • Please measure and calculate the cable length precisely. There is not enough space for wires which are too long. In this pic, they ARE 25mm/1" longer than needed. Reworking them is painful.
步骤 4  ¶
Remove all the extra parts from the PCB, metal frame, and white plastic back. There are 9 of them. Use knife or other cutting tool to cut the plastic. Use cutting tool to cut PCB. Use Diamond impregnated files to cut the metal frame. It's very hard and stiff, you cannot cut it with knife or wire cutters. Or, you may hurt you tool or even the LCD GLASS!! That's a game over" Please be ALWAYS VERY CAREFUL and patient, DO NOT HURT the citcuit or the LCD glass (through the entire upgrade). Smooth all sharp metal edges. Should be 6 of them.
步骤 4  ¶
  • Remove all the extra parts from the PCB, metal frame, and white plastic back. There are 9 of them. Use knife or other cutting tool to cut the plastic. Use cutting tool to cut PCB. Use Diamond impregnated files to cut the metal frame. It's very hard and stiff, you cannot cut it with knife or wire cutters. Or, you may hurt you tool or even the LCD GLASS!! That's a game over"
  • Please be ALWAYS VERY CAREFUL and patient, DO NOT HURT the citcuit or the LCD glass (through the entire upgrade).
  • Smooth all sharp metal edges. Should be 6 of them.
  • After this step, your HV121P01 will look more like the original LCD panel i.e. IAXG01B
步骤 5  ¶
More pics for last step. More pics for last step. More pics for last step.
步骤 5  ¶
  • More pics for last step.
步骤 6  ¶
One more pic for last step.
步骤 6  ¶
  • One more pic for last step.
步骤 7  ¶
Drill four 1.5mm~2mm(1/16"~5/64") diameter, 3mm(1/8") deep holes at the left and right side of panel at the position corresponding to original LCD panel. Do NOT drill the glass!!. 2 will be drilled on metal and then plastic, 2 on plastic. As said before, the metal is very hard! use high quality drill and be patient and avoid overheating, or you'll burn your hand or the plastic and LCD glass.
步骤 7  ¶
  • Drill four 1.5mm~2mm(1/16"~5/64") diameter, 3mm(1/8") deep holes at the left and right side of panel at the position corresponding to original LCD panel. Do NOT drill the glass!!.
  • 2 will be drilled on metal and then plastic, 2 on plastic. As said before, the metal is very hard! use high quality drill and be patient and avoid overheating, or you'll burn your hand or the plastic and LCD glass.
  • In these pics, the upper LCD is the original one, the bottom one is HV121P01.
步骤 8  ¶
Remove the front shield, if any. It's positioned by double sided tape. Should not be very tight. But, still, be very careful about the LCD glass. if you have to break some thing, it should be the shield or tape.
步骤 8  ¶
  • Remove the front shield, if any. It's positioned by double sided tape. Should not be very tight. But, still, be very careful about the LCD glass. if you have to break some thing, it should be the shield or tape.
  • remove any tape, glue.
步骤 9  ¶
Apply some electric tape here, to avoid short circuit.
步骤 9  ¶
  • Apply some electric tape here, to avoid short circuit.
步骤 10  ¶
Connect the Cables. The LVDS cable connector position is different. So the cable will not be flat enough. cut the transparent tape around the wires. Reposition the cable, and then using tape to hold them in position. Hold the PCB with tape.
步骤 10  ¶
  • Connect the Cables.
  • The LVDS cable connector position is different. So the cable will not be flat enough. cut the transparent tape around the wires. Reposition the cable, and then using tape to hold them in position.
  • Hold the PCB with tape.
步骤 11  ¶
screw in 4 screws (not photoed, check LCD guide).
步骤 11  ¶
  • screw in 4 screws (not photoed, check LCD guide).
  • check the cable connections again. Assemble the inverter screw.
  • Power on and test. It's 1400x1050 now.
  • This might be the world's highest resolution 12" PowerBook.
