跳转到主内容
帮助
MacBook Core Duo Right Hinge Mount Replacement
MacBook Core Duo right hinge mount replacement.
  • 作者: iRobot
  • 难度: 中等
The right hinge mount connects the right display hinge to the case. Use this guide to replace yours if it's broken or otherwise damaged.
步骤 1 Right Hinge Mount  ¶
Remove the following 2 screws from the right hinge mount:
  • Remove the following 2 screws from the right hinge mount:
  • One 6 mm Phillips on the left side of the hinge mount.
  • One 10 mm Phillips on the right side of the hinge mount.
  • Lift the hinge mount and attached plastic dust cover out of the computer.
步骤 2  ¶
Slide the plastic dust cover out of its slot in the right hinge mount.
步骤 2  ¶
  • Slide the plastic dust cover out of its slot in the right hinge mount.
