跳转到主内容
帮助
Sony Ericsson T68i Keypad Replacement
缺少前提条件
缺少前提条件
本指南缺少关于如何开始这些步骤的信息。请编写前提指南!
This guide will help you to remove the keypad from your Sony Ericsson T68i.
步骤 1 Keypad  ¶
Remove the battery from the back. Remove the battery from the back.
步骤 1 Keypad  ¶
  • Remove the battery from the back.
步骤 2  ¶
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
步骤 2  ¶
  • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
  • Do not bend it too far down, or else you risk breaking the two bottom clips.
步骤 3  ¶
Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
步骤 3  ¶
  • Unscrew all four Torx T6 screws.
  • Keep in a safe place.
步骤 4  ¶
After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
步骤 4  ¶
  • After removing the screws, the two halves will separate. If not, then pry them gently apart.
