跳转到主内容
帮助
Sanyo VPC-X1200 shutter assembly replacement
标记错误
标记错误
本指南需要更好的标记。请帮助纠正或制作一些标记批注。
This guide helps you to remove and replace the lens unit
步骤 1 Lens Unit  ¶
Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
步骤 1 Lens Unit  ¶
  • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
  • One gate is black and another is white.
步骤 2  ¶
Remove the three silver screws. Three 5.5mm screws
步骤 2  ¶
  • Remove the three silver screws.
  • Three 5.5mm screws
步骤 3  ¶
Lift the lens unit free of the camera.  A spudger can be used to separate the lens unit if necessary.
步骤 3  ¶
  • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
