跳转到主内容
帮助
Disassembling Nokia 6236i Battery
  • 作者: Erik Lindahl
  • 估计时间: 1 - 2 分钟
  • 难度: 非常容易
This will guide you through removing the battery. No tools required.
步骤 1 Disassembling Nokia 6236i Battery  ¶
Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone. Lift the battery case off of the phone.
  • Apply pressure to the battery casing (below the camera) with your thumb and pull towards the bottom of the phone.
  • Lift the battery case off of the phone.
步骤 2  ¶
Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone. The battery should lift out with minimal resistance. The battery should lift out with minimal resistance.
步骤 2  ¶
  • Gently pull the battery out of the phone, using your thumb to apply pressure to the battery at the bottom of the phone.
  • The battery should lift out with minimal resistance.
