跳转到主内容
帮助
iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement
Replace a blown out microphone or a broken headphone jack on your iPad Wi-Fi.
Use this guide to replace your iPad's Headphone Jack/Microphone Assembly.
步骤 1 Headphone Jack/Microphone Assembly  ¶
Use the edge of an iPod opening tool or your fingernail to flip up the ZIF cable retaining flap on the headphone jack socket.
  • Use the edge of an iPod opening tool or your fingernail to flip up the ZIF cable retaining flap on the headphone jack socket.
  • Be sure you pry up on the cable retaining flap, not the socket itself.
步骤 2  ¶
Carefully pull the headphone jack cable out of its socket on the logic board.
步骤 2  ¶
  • Carefully pull the headphone jack cable out of its socket on the logic board.
步骤 3  ¶
Remove the two 2.8 mm T5 Torx screws securing the headphone jack to the rear case.
步骤 3  ¶
  • Remove the two 2.8 mm T5 Torx screws securing the headphone jack to the rear case.
步骤 4  ¶
Remove the headphone jack from the rear case.
步骤 4  ¶
  • Remove the headphone jack from the rear case.
  • Make sure you transfer the rubber sound channel from your old microphone to the new microphone.
  • Before reinstalling the screws, be sure the headphone jack is properly seated in the headphone jack hole cut into the top edge of the rear case.
