跳转到主内容
帮助
Disassembling KDDI Kyocera A5521K Main LCD Screen
标记错误
标记错误
本指南需要更好的标记。请帮助纠正或制作一些标记批注。
These instructions will demonstrate how to remove the main LCD screen from the KDDI Kyocera A5521K.
工具
步骤 1 Main LCD Screen  ¶
Remove the flexible circuit shown using tweezers (or use your fingers if you can manage a firm grip). Remove the flexible circuit shown using tweezers (or use your fingers if you can manage a firm grip).
  • Remove the flexible circuit shown using tweezers (or use your fingers if you can manage a firm grip).
步骤 2  ¶
Unplug the circuit connector. Unplug the circuit connector.
步骤 2  ¶
  • Unplug the circuit connector.
步骤 3  ¶
Grab the phone with both hands. Turnover the phone so that the main screen faces you. Firmly grasp the edges between your thumbs and fingers.
步骤 3  ¶
  • Grab the phone with both hands.
  • Turnover the phone so that the main screen faces you.
  • Firmly grasp the edges between your thumbs and fingers.
  • Carefully push in the LCD screen from the remainder of the phone.
  • Be careful not to break the LCD screen.
步骤 4  ¶
The LCD screen and circuit board should now be partly detached from the frame. The LCD screen and circuit board should now be partly detached from the frame.
步骤 4  ¶
  • The LCD screen and circuit board should now be partly detached from the frame.
步骤 5  ¶
Turn over the phone. Separate the circuit board from the back of the LCD screen.
步骤 5  ¶
  • Turn over the phone.
  • Separate the circuit board from the back of the LCD screen.
步骤 6  ¶
Remove the LCD screen from the phone. Remove the LCD screen from the phone. Remove the LCD screen from the phone.
步骤 6  ¶
  • Remove the LCD screen from the phone.
